Geocraft Error with Ioncube?
Discussion in 'GeoCraft WordPress Theme' started by tony72, Jan 3, 2013.
  1. tony72
    tony72 New Member
    After updating theme to 1.6.6.
    I installed ion cube for a software that i use on my other sites.
    Which required me to create a php5.ini with a zend_extension to call the ioncube for php.5.3.14 that im running. Which my Apache hosting is running with Linux to replace the original php.ini.
    After i found error i Erased php5.ini uploaded original php.ini with no luck.
    Re uploaded php5.ini and Checked my other themes no problem with ion cube or themes work fine no problem at all.
    IS GEOCRAFT THEME COMPATIBLE WITH IONCUBE LOADERS?
    When using geocraft theme Site and admin panel loads with these errors below.
    Notice: Constant SAVE_ALL_CHNG already defined in /home/content/30/10198530/html/wp-content/themes/geocrafttheme/library/text_domains/admin_setting_path.php on line 75
    Notice: Constant TEST_COOKIE already defined in /home/content/30/10198530/html/wp-content/themes/geocrafttheme/library/text_domains/front_end_path.php on line 8
    Notice: Constant A_MSG_ST_EMAIL already defined in /home/content/30/10198530/html/wp-content/themes/geocrafttheme/library/text_domains/front_end_path.php on line 19
    Notice: Constant PW_AGAIN already defined in /home/content/30/10198530/html/wp-content/themes/geocrafttheme/library/text_domains/front_end_path.php on line 44
    Notice: Constant SRCH already defined in /home/content/30/10198530/html/wp-content/themes/geocrafttheme/library/text_domains/template_path.php on line 49
    Notice: Constant EDIT_PROFILE already defined in /home/content/30/10198530/html/wp-content/themes/geocrafttheme/library/text_domains/template_path.php on line 70
    Notice: Constant COMMENT already defined in /home/content/30/10198530/html/wp-content/themes/geocrafttheme/library/text_domains/template_path.php on line 91
    Notice: Constant REQUIRED already defined in /home/content/30/10198530/html/wp-content/themes/geocrafttheme/library/text_domains/template_path.php on line 93
    Notice: Constant ADD_LISTING already defined in /home/content/30/10198530/html/wp-content/themes/geocrafttheme/library/text_domains/template_path.php on line 117
    Notice: Constant ACTIVE already defined in /home/content/30/10198530/html/wp-content/themes/geocrafttheme/library/text_domains/custom_field_path.php on line 26
    Notice: Constant REQUIRED already defined in /home/content/30/10198530/html/wp-content/themes/geocrafttheme/library/text_domains/custom_field_path.php on line 28
    Notice: Constant ACTION already defined in /home/content/30/10198530/html/wp-content/themes/geocrafttheme/library/text_domains/custom_field_path.php on line 38
    Notice: Undefined index: name in /home/content/30/10198530/html/wp-content/themes/geocrafttheme/library/model/ajax_db.php on line 3
    Notice: Undefined index: email in /home/content/30/10198530/html/wp-content/themes/geocrafttheme/library/model/ajax_db.php on line 4
    Notice: Undefined index: contact in /home/content/30/10198530/html/wp-content/themes/geocrafttheme/library/model/ajax_db.php on line 5
    Notice: Undefined index: message in /home/content/30/10198530/html/wp-content/themes/geocrafttheme/library/model/ajax_db.php on line 6
    Notice: Undefined variable: update in /home/content/30/10198530/html/wp-content/themes/geocrafttheme/library/model/db_function.php on line 6
    WordPress database error: [Table '****************.wp_' doesn't exist]
    INSERT INTO `wp_` (`user_name`,`email`,`phone_no`,`message`) VALUES ('','','','')
    Warning: Cannot modify header information - headers already sent by (output started at /home/content/30/10198530/html/wp-content/themes/geocrafttheme/library/text_domains/admin_setting_path.php:75) in /home/content/30/10198530/html/wp-content/themes/geocrafttheme/library/controls/metabox/listing_metabox.php on line 3
    Any help would be very appreciated
    Thanks.
  2. tony72
    tony72 New Member
    Could i please get a reply from staff to this thread?
  3. tony72
    tony72 New Member
    Thanks anyway but i fixed it
