Hello When we try to export listings we get this error:http://prntscr.com/94u9uu This is a complete new install with fresh WP and fresh theme install!
Also No images are attached to listings and you can't edit a listing image in the back end, you just get a blank page! Getting worried here!
And these problems: - On the submit listing form, if you forgot to select something like a category the page refreshes with an error but all the details go missing and you have to start again. It needs to hold the data even if there is an error - Seams to be an error, if you leave the 'free listing' box checked and proceed through to place a listing it says 'you must select a package', it only works if you deselect the free package and the reselect it
Can't save phone number for free listing just says error occurred: http://prntscr.com/94uqyu Have I done something wrong with the setup because so many things are broken or not working!
Hi, Greetings from InkThemes, The occurrence of o many errors at once is a very strange thing for us. It seems that you have done mistake while installing the theme. To determine and fix the issues from our end, we need access to your dashboard. So, send us your website WordPress login details at [email protected] along with the thread link. Your Website URL: WordPress Username: Password We will try to get your issues resolved as soon as possible. Thanks & Regards! Nitin InkThemes.com
Hello, Thanks for the details... Hope you have sent this thread link as well along with your details. We will get back to you soon.. Thanks & Regards! Priyanka InkThemes.com
Ok That new theme apepars to have cleared a few issues. Our map http://185.24.99.209/~towbarquoteco/ shows no pin points on it? We loaded the demo data and put a test on but still it shows us no pin points for the businesses !
Hello, It seems that you have not set the listing location details in your dashboard. So, I would like to suggest you to please add details for once and look after that. Please follow the screenshot given below. Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
