GeoCraft Permalink Settings?
Discussion in 'GeoCraft WordPress Theme' started by thepalco, May 8, 2015.
  1. thepalco
    thepalco Member
    I am having issues with GeoCraft and the nav bar at the top (sign in, etc.) The links just echo back to the home page. The main menu links work fine and the Premium Button Listing in the header is working. The log off and sign on are working just not anything else.
    I think it has something to do with the Permalinks? They seem to be switching? I think it's a Theme issue, but I am not sure? In any case, where can I edit that permanent nav bar menu at the top so the links go to the right pages.
    Thank you!
  2. praveen
    praveen Support Staff
    It seems that you have not set the permalinks...
    Go to Settings=>Permalinks of your dashboard and set the permalink available.
    It will resolve your issue.
    Praveen
  3. thepalco
    thepalco Member
    Thanks Praveen!
