Geocraft -- po fileTranslation
Discussion in 'GeoCraft WordPress Theme' started by aliounn, Dec 15, 2012.
  1. aliounn
    aliounn Member
    I'm using poedit to translate my theme. after translating 70% of the .po file and activate it in the standard format with the .mo file , I see that just some words have been translated. i didn't make any mistake and it's not about specials caracters. for some words , the translation is. ok , but for others they still in english. ????
    I need a help please !!
    thanks
    Please send a list of those words which are not translating through .po file.
  3. aliounn
    aliounn Member
    Here are some words and sentences which are not translating through .po file :
    -Address,Contact Name,Time,Phone No,Listing Title,Enter listing title,Please enter listing address,Address Latitude,Address Longitude,Select Image,Enter contact person name,Listing Description,Recent Listing,Dashboard,write your message,Previous Listing, ..........
    Thank you for your support.
  4. Nitesh
    There is no need to translate these words through .po file. You can translate them go to
    Geocraft settings > custom fields
    Check image for reference
  5. aliounn
    aliounn Member
    I still have some problem with translation, i didn't find the following words and sentences in the po file and custom fields :
    -Dashboard
    -Read More (in home page)
    -IN (Featured IN …… in featured slider)
    -Please Enter User name ( for registration )
    -Please Enter E-mail ( for registration )
    -Please enter password ( for registration )
    -Please enter confirm password ( for registration )
    -Register ( for registration )
    -Log IN
    -ERROR: This email is already registered, please choose another one. ( for registration )
    -ERROR: This username is already registered, please choose another one. ( for registration )
    -Welcome (in Dashboard)
    -Your Listings (in Dashboard)
    -Publish (in Dashboard)
    -Pending (in Dashboard)
    -Items (in Dashboard)
    -Back (in Dashboard)
    -Update Profile (in Dashboard)
    -My Subscriptions (in Dashboard)
    -Your Reviews (in Dashboard)
    -Expired Listings (in Dashboard)
    -Review your Listing (in Dashboard)
    thank you for your support
  6. Nitesh
    We will check and update possible text in our next version.
  7. aliounn
    aliounn Member
    Do i need to do this manually with some words before the next update ?
  8. aliounn
    aliounn Member
    what about this form. how can i translate words? please see the atached file
  9. Nitesh
    Go to the
    geocrafttheme \ library \ controls \ module_functions.php
    and edit text as shown in image.
    You can change other slugs from
    geocrafttheme\library\text_domains\ front_end_path.php
  10. aliounn
    aliounn Member
    thank you Nitesh . is the new update (1.6.6) include these words in po file ? if i translate directy from php files, do i need do it for each update ?
  11. Nitesh
    You need to change lead capture form text manually through module_functions.php as shown above.
    Other slugs are available in our latest version (1.6.6) of theme.
  12. aliounn
    aliounn Member
    Hi Nitesh,
    How can i translate the word " IN " present in text of featured slider as shown in the attached file ? i did not find it .
    also where can i find the geocraft_get_option() fonction ? it is used many time , but i didn't see where you create it.
    thank you.
      File size:
      288.7 KB
      5
  13. Nitesh
    Go to the
    Theme directory > taxonomy-listcat.php and follow instructions as shown in image.
