geocrafttheme translation issues
Discussion in 'GeoCraft WordPress Theme' started by kamelia, Feb 23, 2016.
  1. kamelia
    kamelia New Member
    Hello, I am translating the geocrafttheme with the plugin loco translate but some translated text lines do not appear. Some others - do appear, which means that it is not a plugin configuration issue. Including I have translated some text chains directly from the folder front_end and the translation of this text line do not appear either.Do you have an idea about what should be done to solve this issue
    Could you please send us some edited screenshot of the concerned area so that we can better assist you?
  3. kamelia
    kamelia New Member
  4. kamelia
    kamelia New Member
    In addition to these two sections I have not been able to translate the submission form for listings, therefore any help in this regard will also be welcome.
    Thanks in advance
  5. priya
    Please follow the screenshots given below.
  6. kamelia
    kamelia New Member
    Hi, I have tried to follow your indications but I had several issues. The first one is that in my admin panel in wordpress the theme editor does not appear, just editor appears.Because of that I tried to edit the archives from the c panel but the structure of the folders is not the same and some archives do not have the same name or they do not appear. Is this a theme installation error and how do you think I can resolve it and continue with the theme translation
  7. priya
  8. kamelia
    kamelia New Member
    Hello Priyanka after installing the plugin that you have recommended to me, it is evident that the folders in my case are not distributed the same way and I just cannot localize some archives and a clear example for it is listings.php that had to be in the templates folder but as you can see from the screenshot in this folder I have just two files and none of them has this name. What do you think is the reason and how we can resolve it.
    Thanks in advance
  9. priya
    Would you please reinstall the theme once again from the members area and check after that..
    Download the GeoCraft theme by logging in your members account:
    Next, you have to extract the zip file and rename that folder geocraft like geocraft_new,
    Again, you would need to create a zip file of that renamed folder (say: geocraft_new.zip),
    Then, activate your theme,
    If still you will be in the same issue, please provide us your dashboard credentials at [email protected] so that we can figure out the issue and able to resolve that..
    InkThemes.comThanks,
