Geolocation for every businees.
Discussion in 'GeoCraft WordPress Theme' started by jecr77, Apr 4, 2016.
  1. jecr77
    jecr77 New Member
    Hi, before I purchased this theme I asked if I would be able to place a pin for every single business on the general map (homepage map), I was told YES, and now I can't find how to do that, I know I can place a Listing Location, but what I want is that every business shows on the map of home page.
    Is this possible?
  3. jecr77
    jecr77 New Member
    No, but thanks!
    I think what I want is not possible.
    Hello...
    Sorry if this didn't resolve your issue...
    But still, could you please elaborate your requirement a bit more along with some edited screenshot so that I can better try to resolve your issue...
  5. 4144diane
    4144diane New Member
    Tavistock, Devon. United Kingdom
    Hello
    I have a similar problem to jecr77, my homepage map looks like this:
    http://prntscr.com/ay96qy
    Really, I would like it to zoom in more on a local area. I have a child theme set up, can I do this in there?
    http://prntscr.com/ay96zs
    But in an ideal world, I would like it to display location pins for the company's that are advertising with the directory, see below.
    http://prntscr.com/ay96aj
    I also have other issues with the address map; on the add new listing page, under the map Please enter listing address. eg. : 1870 Beloit Ave Apartment' West Los Angeles' CA 90025 is displayed, I would like this to be more relevant i.e. 102 High Street, Crediton, Devon EX17 3LF.
    http://prntscr.com/ay9d7n
    I have duplicated class-install.php and dashboard_path.php into my child theme and changed the required details, but this still doesn't update, should I be changing these details somewhere as well?
    Sorry, so many questions.
    Look forward to your reply.
    Kind regards
    Diane
  6. 4144diane
    Hello again
    I have now fixed the zoom issue, but still can't get the pins to display on the map!
    http://prntscr.com/ay9m9m
    This is a listing location with a valid postal code, but it does not display on the map.
    Kind regards Diane
  7. 4144diane
    Hello
    I have also now solved the problem with the incorrect address, just need the pins to work now!
    Kind regards
    Diane
  8. priya
    Hello Diane..
    I have replied you at your another thread..
