Hi I am currently running Gommero Theme 1.3, I would like to update to Gommero Pro. I was hoping to just FTP the files overtop of the old theme, but the files and folders are completely different. I installed the pro version, but it set to all the default settings, It seem like i would have to customize the entire theme to match the current site. How can i use the pro them BUT keep all the current look and feel of the Gommero Theme 1.3 and its customization? Is this possible? Thanks
Hello, Greetings from InkThemes, Will you please allow us to check your website dashboard. So that we can check and do the needful. I look forward to hearing from you. Regards, Akbar InkThemes.com
Hello, Greetings from InkThemes, Just for the confirmation, Your issue has been fixed or we missed something on our end? I look forward to hearing from you. Regards, Akbar InkThemes.com
