Hi. I need some help with where to put my Google Adwords Tracking Code. I'd like to track my conversions, so I plan to put the code on the page AFTER a visitor clicks Send Message in the Lead Box and/or Send Message in the Contact Us Form. Where do I put the code because the page refreshes and shows "your message has been sent..." but still has the same URL as before they sent the message. Thanks a bunch! Your support rocks!
Hello, That message comes from leads_class.php file Go to functions > leads_class.php present in your theme directory and you can put your code there.
Do I just put in anywhere in that PHP file or is there a specific place? Also, where does the Google Adwords Tracking Code go for the Contact Us "Sent" Page? Thanks for the quick response. I appreciate it!
Hi. Can you please let me know specifically where to put the Google Adwords Tracking Code for the Lead Capture "Sent Message" Page as well as the Contact Us "Sent Message" Page? I did what you told me before ^^ and I was getting an error while on the /wp-admin login page. I said you can't change the lead_class.php in Header, etc. Can you please let me know where to put the Code so I don't mess anything up? Thanks!
Hello, You can add your code in header.php present in your theme directory, It will works for both Lead capture as well as Contact us It may solve your issue.
Hi. Thanks for the response! I've added the Code where specified, however my client says that the conversion isn't for the lead capture, but rather the entire homepage. Can you let me know if I've put the Code in the right place? http://supandatruck.com Thanks! ***Is it possible to create a separate URL so that the first one is supandatruck.com and then the second one when someone fills out the form is supandatruck.com/completed or something like that?***
Hello, Theme sharing common header for all the pages, header.php file is the best place for adding code, So follow the instruction provided above it will work fine.
Ok, thank you. **Is it possible to create a separate URL so that the first one is supandatruck.com and then the second one when someone fills out the form is supandatruck.com/completed or something like that?**
Hi, just to clarify - the Google Conversion Code NEEDS to go ONLY on the Page which reads "your message was submitted" from the Lead Capture and Contact Us pages AFTER someone has submitted info/purchase. If it's placed on the page BEFORE they actually submit info or purchase something, it is of NO use. Where should I put the code in order to achieve this? Currently, when I view the Page Source, the code shows up on both BEFORE and AFTER the information is submitted (A Conversion), which is of NO use? Thanks so much for the great support!
Haven't heard back. Is there anything to do about the tracking code so your theme uses it properly? What are my options? Thanks!
Hello, It is not possible to add Adwords conversation tracking code in Lead capture form. For contact us page Go to template-contact.php present in your theme directory and follow the instruction as shown in image given below This will solve your issue.
