Google Analytics "Tracking Not Installed" for ColorWay Theme Pro v.2.1.6
Discussion in 'ColorWay WordPress Theme' started by tomvaughan64, Jul 20, 2013.
  1. tomvaughan64
    tomvaughan64 New Member
    Google Analytics reads: Tracking Not Installed
    I have installed the tracking code script in Appearance>General Settings>Tracking Code and not working.
    I also tried the workaround (found in one of the forum threads here) which is go to Appearance>Editor>Edit the header.php and paste the Google Analytics tracking code script.
    This didn't work either.
    I have ColorWay Theme Pro installed, the latest version v.2.1.6
    Any advice?
    Marie
    If we add Google Analytics code in
    Theme option > General settings > Google tracking code, Then theme will automatically place it just above </head> tag.
    But because of some reason, if it is not working at your site then you can manually add GA code in the header.php.
    For it Go to the
    Appearance > Editor > header.php and place code just above </head> tag.
    Check link given below for reference.
    https://support.google.com/analytics/answer/1008083?hl=en
