google fonts issue
Discussion in 'RoadFighter WordPress Theme' started by smarta, Sep 25, 2015.
  1. smarta
    smarta Member
    I have been trying to add google fonts to the site at
    http://www.smartawordpress.com
    I have tried several plug-ins - none of which have worked
    I have added the following to the custom css
    body {
    font-family:'http://fonts.googleapis.com/css?family=Lato', 'verdana', sans-serif;
    font-size:13px;
    line-height:25px;
    color:#373636;
    /*background:url(images/bg.png) repeat;*/
    background-attachment:fixed;
    h1, h2, h3, h4, h5, h6 {
    font-family:'http://fonts.googleapis.com/css?family=Quicksand:700', sans-serif;
    font-weight:bold;
    color:#490d67;
    the font colour is changing but seems to be being overridden by the default Champagne and Limosuines font
    Could you please add the google font in "style.css" file (Appearance=>Theme Editior=>style.css) rather than custom CSS field for once..
    To edit the file, you can use "wp-editor" plugin.
  3. smarta
    smarta Member
    ok
    I now have in the css file
    @import url(css/reset.css);
    @import url(css/960_24_col_responsive.css);
    @import url(css/prettyPhoto.css);
    @import url(css/shortcode.css);
    @import url(https://fonts.googleapis.com/css?family=Quicksand:700);
    @import url(https://fonts.googleapis.com/css?family=Monserrat);
    body {
        font-family:tahoma, 'verdana', 'Lucida Grande', HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, sans-serif;
        font-size:13px;
        line-height:25px;
        color:#373636;
        font-family:"Champagne & Limousines", Arial, sans-serif;
        font-weight:bold;
        color:#010101;
    and in my custom css I have
    body {
        font-family:'http://fonts.googleapis.com/css?family=Monserrat', 'verdana', sans-serif;
        font-weight:bold;
        color:#490d67;
    yet the champagne font still seems to be overriding and the body copy is not in monserrat
    I have tried several combinations but can't get it to work
    can you tell me what I am doing wrong ?
  4. nitin
    nitin Guest
    I really appreciate your efforts in exploring the things and sharing your knowledge here.
    It might have worked for you, but if you are still in the issue it seems that you are little diverted from the proper settings.
    To figure out the root cause of the problem we need access to your Dashboard.
    Your Website URL:
    WordPress Username:
    Password
    We will try to fix it for you.
    Nitin
  5. smarta
    smarta Member
    ok - info sent
  6. nitin
    nitin Guest
    We have successfully received your query and is being forwarded to our developers,
    As InkThemes has been receiving a high volume of support requests our developers are busy at this moment, I will try to pull them on your issue and will get back to you with a positive response ASAP.
    Hope you understand.
    Regards!
    Nitin
  7. priya
    You site is on the protected mode so we are unable to access your site.
    so please send your password at our mail id (mentioned above).
  8. smarta
    smarta Member
    the password for site access is
    aayt2105
    sorry about that - I thought i had included that info
    I have previously sent the wordpress log-in details - let me know if you need them again
  9. priya
    Thanks for the details...
    We will get back to you ASAP.
  10. smarta
    smarta Member
    any news with this problem?
  11. smarta
    smarta Member
    is it to do with cufon ?
    I really need to get this fixed as my client wants to launch their site
  12. smarta
    smarta Member
    I am now having the same problem with this site
    http://smartartshosting.com.au/southside/
    I have
        font-family:"Arial Black", verdana, Arial, sans-serif;
        font-weight:normal;
        color:#010101;
    in both the custom css and the style.css files
    yet the other font is overriding
  13. priya
    We have sent you a mail.
    Kindly check your mail and reply...
  14. smarta
    smarta Member
    the aayt2015 password just worked for me at http://smartawordpress.com
    I will re-send admin passwords for both sites to enquiry@
  15. priya
    We have replied you at mail.
    Kindly check...
  16. smarta
    smarta Member
    ok thank you very much - The fonts are now working
    however - much of my custom css is not working now - I am not sure if it is related to the cufon issue
    2 pieces of custom css were working before you made the change but now are not - the are
    .slider-wrapper {
          background: none !important;
    padding-bottom: 2px !important;
    margin-bottom: 2px !important;
    which is to remove the grey shadow under the slider
    and this
    @media only screen and (max-width: 480px) and (min-width: 401px){
      .slider-container {
        height: 375px !important;
    @media only screen and (max-width: 767px) and (min-width: 481px){
    .header {
      margin-top:0px !important;
    .flexslider .slides img {
          margin-top: 179px !important;
    .slider-container {
      height: 467px !important;
    @media only screen and (max-width: 960px) and (min-width: 768px){
      margin-top: 148px !important;
    @media only screen and (max-width: 1140px) and (min-width: 961px){
        margin-top: 83px !important;
    @media only screen and (max-width: 1400px) and (min-width: 1141px){
        margin-top: 54px !important;
    which is from this thread http://www.inkthemes.com/community/threads/slider-scaling.18567/
    to stop the menu covering the logo image
  17. smarta
    smarta Member
    I also notice on another site using roadfighter that the custom css (I have the same custom css as above in this site too) is not working now either
    the slider scaling was working yesterday
    and some new items I have added today do not seem to be working
    eg this one
    .header_wrapper {
        margin-top: 0px !important;
    and a couple of others
    I sent login details for both these sites yesterday if you need them
  18. smarta
    smarta Member
    can somebody get back to me on this - its been a few days now
    I have 2 sites (as told above) where much of the custom CSS is not working
  19. priya
    Could you please clear your cache for once and look after that..
    If you will still have the same issue then let us know we will look over the issue through your provided details.
  20. smarta
    smarta Member
    ok
    I seem to have corrected the css problem (there was a bracket missing)
    however on the site http://smartartshosting.com.au/southside/
    the font replacement is still not working on the Headings
    I have re-set the style.css file to the default and I have added the following to the Custom Css
    body {
        font-family:verdana, 'Lucida Grande', HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, sans-serif;
        font-size:13px;
        line-height:25px;
        color:#373636;
        font-weight:normal;
        color:#010101;
    The Verdana body copy is working but the Arial Black is overridden by the Champagne & Limousines font
    I have re-sent login details for this site
