Google Map API problem
Discussion in 'InkThemes-Support Working Hours' started by greg2000, Feb 7, 2019.
  1. greg2000
    greg2000 New Member
    Kindly check Google map is not working on my website Kindly solve this problem as soon as possible.Waiting for prompt response.
    Check attachment.
  2. greg2000
    greg2000 New Member
    waiting for reply
  3. akbar92
    Greeting from InkThemes,
    Kindly generate your own google map API key and place the generated API key in the theme options Google Map API key option.
    If the issue still persists then,
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    We will figure out the issue and let you know.
    Akbar
  4. greg2000
    greg2000 New Member
  5. greg2000
    greg2000 New Member
    Already added my own generated API key and above error is happening while consoling.
    Check my website:
    vulsinidirectory.com
  6. akbar92
    I hope the map issue is now resolved as we have followed you up there using the Email.
    And the problem was that you have provided the listing address correctly.
    Let us know if you need any further help, we will be ready to do so.
    Akbar
  7. greg2000
    greg2000 New Member
    How to sync listing locations on main home page and on other business listings.Any video or article will be helpful.
  8. akbar92
    Hello Greg,
    We have added our own map API key, kindly generate the paid Map API key and after that remove ours.
    And for your help, I have made a video and since it is too large so I am sending it to you via Email and we will follow you up there.
    Just have a look at it.
    Akbar
