Hello, Thanks for reaching out us, You might have not used the correct set of Google Map API Keys in the theme. Kindly generate the correct Google Map API Keys and place them in the theme options. This will surely help you out. If this doesn't help then just share the below-mentioned credential details at [email protected] along with the thread link. WordPress Website URL: - WordPress Username: - WordPress Password: - We will look into the issue and do the needful for you. Regards, Shemaela InkThemes.com
Hello, Greeting from InkThemes, Here is the link for generating the Google Map API keys: https://developers.google.com/maps/documentation/javascript/get-api-key I am also attaching a video for you kindly have look: https://screenpresso.com/=E9gec I hope this will help you. Let us know if you need further assistance, we will be happy to assist you. Regards, Shemaela InkThemes.com
Hello, Greeting from InkThemes, Yes, now you need to pay Google for getting Map API keys as they take charge for this. Sometimes before this was free of cost. So to get the Google Map API keys kindly make the payment and you will get your valid API keys which you can use anywhere you want. Regards, Shemaela InkThemes.com
Hello. I have a google API key, and inputed it in the field. There is an error in the field that says "map center location". I had just previously entered an address of exactly this: 1190 W Ash St, Windsor, CO 80550 Now the fields says "oops. there is something wrong here and had grey circles in it as well I cannot clear the field. Is there something I can do to go forward?
Hello, Greeting from InkThemes, Will you please allow us to check your website dashboard for once? Kindly send the below-mentioned credential details at [email protected] along with the thread link. WordPress Website URL: - WordPress Username: - WordPress Password: - We will check the issue and do the needful for you. Regards, Shemaela InkThemes.com
