Great theme. Couple of styling questions
Discussion in 'Harrington- A WordPress Business Theme.' started by jordielindstrom, Feb 2, 2014.
  1. jordielindstrom
    jordielindstrom New Member
    - How to remove border around slider
    - How to change slider size
    - How to change or remove the animation effects on slider.
    - How to change text colour on tabs
    1. Paste the code given below in Custom CSS section
    .sy-slides-crop {
    border: none;
    2. Paste the code given below in Custom CSS section
    .sy-slides-wrap {
    height: 450px;
    width: 800px;
    .slider_container{
    height: 445px;
    width: 800px;
    margin-left: 155px;
    background-size: 800px;
    background-position-x: 15px;
    You can adjust the above values as per your requirement.
    3. Go to js > custom.js present in your theme directory and follow the instruction shown in the image given below.
    4. Paste the code given below in Custom CSS section
    .sy-caption-wrap .sy-caption h1 {
    color: red;
    In place "red" you can put your color or color code.
  3. mgunaseg
    mgunaseg New Member
    Hi - I'm about to buy the Harrington and just wondering if the suggestion for changing the transition from 'kenburns' to 'fade' works. Thank you!
  4. Piyush
    After that paste the code given below in Custom CSS section
    .sy-slide {
    margin-left: 0px;
    .sy-slide > a > img {
    height: 495px;
