Half of the page is visible and other half is not visible in mobile
Discussion in 'Dzonia WordPress Theme' started by syed, Jul 4, 2014.
  1. syed
    syed New Member
    I want to delete this thread
    Could you please specify your issue with the help of screenshot images and also share us your website link so that we can check your issue.
  3. Piyush
  4. Piyush
    We are unable to see your website because it is in under construction mode.
    Please make it visible to us so that we can check your issue.
  5. Piyush
    I have checked your website on mobile device but not found such issue.
    Your website is working fine in mobile view.
    See the screenshot for reference.
    You can check it on another devices.
  6. Gourav
    We have open your website and it is in the under-construction mode, therefore it is not possible to check your issue. So deactivate the under-construction mode and inform us, So we will check your issue.
    Gourav Shrivastava
  7. Piyush
    1. Your second issue has been resolved you can check your website.
    2. For your third issue,
    .content_wrapper {
    padding-top: 32px;
    You can change the value of "padding-top" as per your requirement.
  8. Piyush
    Thanks for contacting us.
    Actually you have added "Table" in your page. And Table creates some problem in mobile view.
    So we are sending you a link, in that you will get how to create table which fits for your website.
    You can easily create it.
    Just look at "No More Tables" section.
    It will solve your issue.
    Here is the link : http://elvery.net/demo/responsive-tables/
    Also sending you screenshot for reference : http://screencast.com/t/jA8L44jsFz
    Have a nice day.
