I'm having problems getting the lightbox gallery working, I'm on WordPress 3.5.1 so the manual looks a little different to what I'm expecting. The URL is http://www.scrumdumblys.co.uk/gallery/ is there something I'm doing wrong? Kind regards, Agility
I do seem to have some problems with this theme. Jetpack is installed, and the gallery/carousel options from JetPack don't work either, they throw a javascript error. I also use a plugin called Cookie Control on my other sites, but when this is activated, the site doesn't display at all. If I shift over to the default Twenty Twelve theme (or indeed a different InkThemes theme), everything starts working as expected. I've just reinstalled the theme to no avail, I've also put my cusomtizations into a child theme which hasn't helped.
Follow the link given below http://www.inkthemes.com/community/threads/gallery-page-with-wordpress-3-5.1118/#post-3992 It helps you to create gallery page in right way.
Hi Priyush, I've tried that, but it still doesn't work. Just to make sure I'm not going crazy, I've just downloaded the "Slice" theme to the site and everything works perfectly - the Gallery, the JetPack carousel, the Cookie Control plugin. As soon as I switch back to Infoway, it all stops working again. I was able to get the Cookie Control plugin working using the same little hack that judester posted here, but the gallery/JetPack still didn't work: http://www.inkthemes.com/community/threads/contact-form-7-plugin-spinning-ajax-fix.2502/
Please provide the following information listed below. Thread Link: Your Website URL: WordPress Username: WordPress Password: Send this information on our email at [email protected] We will check and resolve your issue
