Hi There I am using the Infoway theme and all was okay until I went to add "Google translator" and "Display Widget" plugins. Now I cannot use any other new widgets in the side area of my website. No new widget will save and stay for me. This message did come up "Fatal error: Allowed memory size of 67108864 bytes exhausted (tried to allocate 7711149 bytes) in /home/travelst/public_html/wp-includes/wp-db.php on line 880". there is now message now but no newly added widgets will work. Could any widget or plugins interfere with the Infoway Theme? Also I wanted to add Google Translate code "<?php echo do_shortcode('[google-translator]'); ?>" into the top right hand corner where the Contact Details are put, is there any Custom CSS code I could use to make this work for me? Need help please. Sheena
Hello, Theme is compatible with "Google translate" plugin. I think "Display Widget" plugins is creating this problem. Please search any alternate plugin for it. To add "<?php echo do_shortcode('[google-translator]'); ?>" code. Open "header.php" and add ode as shown in the image. Thanks & Regards Nitesh Raghuwanshi
