Header and Footer colours
Discussion in 'Figero WordPress Theme' started by rmvc, Jan 29, 2015.
  1. rmvc
    rmvc Member
    How do I change the header and footer colours in FigeroPro Responsive?
  2. praveen
    praveen Support Staff
    .header-container {
    background: green;
    .main-footer {
    background: red;
    Praveen
  3. rmvc
    rmvc Member
    Thanks Praveen - also how do chand the Theme Stylesheet to a colour other than the seven default ones
  4. praveen
    This theme is available in the limited seven colors only.
    So if you need to change the color of theme, then you have to manually use customized css code.
    Praveen
  5. rmvc
    rmvc Member
    Dos that mean just editing the CSS stylesheet ?
  6. Pramod
    Pramod Guest
    Hello!
    You can edit style.css or add code in custom CSS box
    Appearance=> Theme options=> Styling option
    Pramod
  7. rmvc
    rmvc Member
    Thank you
