Header and Listing Banners
Discussion in 'GeoCraft WordPress Theme' started by aster media, Oct 14, 2014.
  1. aster media
    aster media Member
    Can you give me an example of a header (visual and script)and a listing banner, such to learn how to create and add them ? Thanks!
  2. Pramod
    Pramod Guest
  3. aster media
    aster media Member
    Your support video does not mention anything about the 'ad setting' feature. Your link shows a banner ad on the front page, but a header banner is not present; I assume it replaces the default colour bar header?
    Could you give me examples of the code or script used to add these features please?
  4. Pramod
    Pramod Guest
    You can use two banners for ad. Are you talking about header section where logo is present??
    For adding two banners in your front page you can find option in your dashboard when you install the theme.
    Pramod
  5. aster media
    aster media Member
    Yes, I'm taling about both options, header and listing banner. I'm aware of the ad setting options in the theme directory. My question to you is about the codes to be used to place the banner ads. Can you give me an example of such a code for both header and listing positions?
  6. Pramod
    Pramod Guest
    You can use html code there for banner. An example of html code is
    <a href="link-for-add" target="_blank" ><img src="link of image" /></a>
    Pramod
