Header color and more changes
Discussion in 'RoadFighter WordPress Theme' started by lukasno4, Feb 16, 2017.
  1. lukasno4
    lukasno4 New Member
    Hi
    I want to make some changes:
    1. Header color white on every sites
    2. menu in centre on header without border
    3. change menu fonts
    4. fix mobile issue, display logo on top
    5. can i make boxes with films and photos the same like on first page and don't use menu drop
    6. how to add translate botton on top right
    my site: mcfstudio.pl
  2. Naveen
    1) It seems you want to white colored header on all pages of your site, for this, you need to paste the below custom CSS code in Dahshboard->Appearance->Theme Options->Styling settings->Custom CSS field.
    .header_container.not_home {
        background: #fff!important;
        border-bottom: none!important;
    2) Can you please share the edited screenshot of the concerned area (Menu Location) of your site?
    3) Which font style do you want to use there? Just let us know, we can tell you the exact custom CSS code for that.
    4)We can resolve this from your site,
    Kindly, share your WordPress admin credentials at [email protected] along with this thread URL:
    WordPress site login URL:
    WordPress admin username:
    WordPress admin password:
    I will check and do the needful.
    5) Can you please share the edited screenshot of the concerned area (Menu Location) of your site?
    6) You can make use of PolyLang plugin with our theme and translate your site in multiple languages, then, you can display your site in multiple languages adding language button in your site.
    Here is the plugin link: https://wordpress.org/plugins/polylang/
    I hope you find the above information helpful,
    I will be glad to assist you,
    Warm Regards!
    Naveen Kolhe
  3. nitin
    nitin Guest
    Hope you are doing good...!
    I would like to assist you on your issue(s) one-by-one in the series of your queries.
    You would be glad to know that we removed the border of the header menu as per your requirements.
    To change the font in your theme, you can use any of the plugin mentioned below:-
    Use Any Font https://wordpress.org/plugins/use-any-font/
    Font - official webfonts https://wordpress.org/plugins/font/
    Easy Google Fonts https://wordpress.org/plugins/easy-google-fonts/
    You would be glad to know that we have fixed the issue as per your requirements. Now the logo is appearing properly. The space that you are facing now is because of the external CSS that you have added in your website.
    I regret to let you know that this could not be made possible.
    The button that you are using is from a plugin and hence cannot be modified externally.
    7. It’s possible to make my contact form full responsible on mobile phones
    The form that you have used is a contact form 7 form. Kindly contact the plugin author to get assistance in making the form responsive. If there's any setting from the backend or the admin panel of the plugin, you can set it from there also.
    8. how to make slider first photos below menu on main page
    Sorry to say but I didn't get your words. Kindly explain your requirement in details do that we could assist you accordingly.
    Hope this helps...!
    Nitin
