Header Custimization
Discussion in 'Black Horse WordPress Theme' started by frederickads, Oct 8, 2015.
  1. frederickads
    frederickads New Member
    Is it possible with customization to change the header / menu background from a solid color to an image? I would also like to use a custom font for the menu text if possible.
    See attached.
    Thanks in advance!
    Could you please explain your issue with some edited screenshot along with reference and url as well so that we cam better assist you?
