Header Divider
Discussion in 'GeoCraft WordPress Theme' started by rdeshazer, May 7, 2015.
  1. rdeshazer
    rdeshazer Member
    USA
    1. 1st header and 2nd header - between the two their is a gray divider line, can the divider line be "White"? www.squirrlit.com
    see atachement
    • rec.pdf
      File size:
      200.2 KB
      4
  2. sameerwalkar
    sameerwalkar Guest
    Kindly apply the below CSS code,
    .top_strip{
    border-bottom: 1px solid #fff;
    Also if you are unable to create screenshots then you can use www.screenpresso.com
    that will help you to create screenshots easily.
  3. rdeshazer
    rdeshazer Member
    USA
    Thanks that work!! and thanks for the screenshot suggestion!!
