Header font not changing
Discussion in 'RoadFighter WordPress Theme' started by midtownmft, Mar 5, 2014.
  1. midtownmft
    midtownmft New Member
    Hi...I want the headers (H1,H2, etc...) to be arial. I'm using this code:
    h1, h2, h3, h4, h5, h6 {
    font: Arial;
    font-weight:normal;
    color:#010101;
    The font is not changing. Please help...thanks!
  2. midtownmft
  3. Piyush
    Go to js > custom.js present in your theme directory and remove the code given below
    //Cufon replacement
    Cufon.replace('h1')('h1:hover')('h2')('h3')('h4')('h5')('h6');
    Now,
    Paste this code in Custom CSS
    font-family: symbol ! important;
    font-weight:normal ! important;
    color: red ! important;
    In place of "symbol" you can put your font type.
