Hi, I´m trying to set my page up prrety like the model: http://inkthemes.com/wptheme/butterbelly-theme/ My problem is that I can´t set the title a little transparente over the slider as we can see in the model. I´d like to put the title like this, where is "ButterBelly Bussiness Wordpress Theme". Does anybody know how can I fix that? thank you.
Hello, Upload transparent background image for the logo from the custom logo section (Appearance > Theme Options > General Settings ). To make the image background transparent you can use Photoshop tool or any other photo editing tool.
Well, it didn´t work. I´d like to try other way, which is to put no logo and let no distance between the main and the slider. Is that possible? Thank you!
Hello, Paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: .header_container.home { display: none; } This will solve your issue.
Well, It didn´t work. I have followed that instructions but the problem is still there as you can see on next link. http://www.brumattiestofados.com.br/ I think no one code that I put in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) has worked. Don´t know why. Is there anyway to fix it? Thank you.
Hello, Go to Settings > Reading and follow the instruction as shown in image given below This will solve your issue. Thanks & Regards Gourav Shrivastava
