header top right
Discussion in 'GeoCraft WordPress Theme' started by joseph2004, Jan 15, 2018.
  1. joseph2004
    joseph2004 New Member
    i have tried cancelling the $26 sign but couldn't how do i go about it?
  2. akbar92
    Akbar
  3. mealea
    mealea New Member
    Do you want to remove the yellow image link in the header upper right hand side on the home page that says "Post Your Business Listing at $..."
    If so then this is the post submission button, you can simply insert the following code in the Custom CSS field located under Dashboard->GeoSettings->Theme Options->Stylings Settings->Custom CSS
    .header_wrapper .header .post_btn {
    display: none!important;
    Cheers.
    nexxus likes this.
