hi i have 2 issues i hope you'll assist 1. in some part of the home page the hebrew fonts are not appearing. please provide with the custom code to paste in the theme option editor 2. i also need the site to allign rtl. plz advice on how to do that site is: http://go.sdmmedia.net/ tnx
Hello, 1.For your first issue Go to js > custom.js present in your theme directory and remove the code given below Code: //Cufon Replacement in heading jQuery(document).ready(function() { //Cufon.replace('h1')('h2')('h3')('h4')('h5')('h6'); Cufon.replace('h1, h2, h3, h4, h5, h6,#menu li a'); }); 2.For your second issue We are working on theme to make it RTL, We will release RTL supported Gommero theme in our next version update and we will inform you after such update.
thanks for your reply 1/ i didn't find the code that I need to remove. could you please point me to where that code can be found, a screen shot will be very helpful if that is not too much trouble 2/ about the 2nd issue is now resolved, just a matter of adding 1 line of code in the header appreciate all the help
Hello, You will not get theme directory in your dashboard. You can edit custom.js file through FTP. Open your Theme directory (through FTP) > js Download custom.js file from there, Edit it, Then again upload it.
ok, i've downloaded the js file via the FTP. still don't know which file to edit, there are lots of files in the JS folder, several with the name CUSTOM in it + i've searched other files in that folder & still didn't find the code could you please tell me where that line of code is located instead of me just guessing where it could be found
Hello, If you are not comfortable to finding the custom.js file to remove the cufon, There is also a another method for removing cufon Go to Appearance > Editor > Theme Functions(functions.php) and remove the code given below Code: wp_enqueue_script( 'cufon-ui', get_bloginfo('template_directory').'/js/cufon-yui.js', array('jquery')); Sending image for reference This will solve your issue.
thank you that did the trick I had a very similar line of code: wp_enqueue_script( 'cufon-ui', get_bloginfo('stylesheet_directory').'/js/cufon-yui.js', array('jquery')); i removed it & problem solved tnx again
Hello, RTL supported Gummero theme is released, Download updated version of theme from your members area and upload it.
I TRIED IT, DIDNT APPEAR WELL. ITS BETTER TO JUST PASTE THE CODE <html dir="rtl" lang="he-IL"> above the <head> tag tnx
Hello, Go to Appearance > Theme Options > Styling Options > Theme Language and select RTL from there, It works fine.
