Hi I was trying to translate some texts in my website as you answered to another member where to do it and suddenly in my website appears this message Parse error: syntax error, unexpected 'DE' (T_STRING), expecting ',' or ';' in /home/datapeke/public_html/directorio/wp-content/themes/geocrafttheme-v2-2/library/front_end/listing_submit_form.php on line 15 My website is: http://directorio.datapekes.com
Hello ! Please re-install the theme or download a fresh copy of theme and replace your listing_submit_form.php file with new theme file. Thanks & Regards Pramod
Hello! Your site is not loading on browsers please ask this from hosting provider. Thanks & Regards Pramod
I guess that you have a few options here. 1. Try to find where you inserted an incorrect character when last modifying your site. 2. If still a problem, FTP into your site and replace the listing_submit_form.php file as suggested by Pramod. 3. If still no go then bite the bullet and revert to your last backup with possible data loss. 4. Finally, delete everything and install a new version from scratch as a last resort. Hmm . . . just looked at your site and it seems to be working OK anyway. Roger B
