Hi, I need help activating the "pro"version of color way responsive. I'm hoping it won't alter my website too much. I also am not sure I want the responsive feature, is there a way to activate/de-activate it, or better yet, give the option for the user to select the full page vs mobilized version? Thanks, Morse www.kingsbrookvet.com
Hello, After uploading responsive theme. Your site will look same as it is now in pc. It's layout will change in iPad and mobile devices. Just upload "Colorwaypro responsive" theme in your dashboard, Activate and check it in mobile device. If you like that change, then keep it, Otherwise again activate old non responsive theme. All your content and links will remain intact while doing this. Note: I suggest you to use responsive theme. It is in demand now a days.
Hi Nitesh-- I have customized the theme a bit- if I upload the Colorway Responsive theme will all of the changes be affected? How would you best suggest I go about this? I can't even remember to be honest the changes I've made to the html and CSS. I suppose I can always go back to the my edited theme... Correct? I appreciate your help! For reference, my site is http://www.elitemakeupdesigns.com
Hello, If you have make change in .php files then you will loss your changes.Your theme option content and custom CSS will remain intact. Your non-responsive theme is remain in your dashboard any time you can switch to your old theme.
