Help creating hyperlink on an image and an email address in Top Right Banner
Discussion in 'Local Business WordPress Theme' started by brooke71, May 23, 2014.
  1. brooke71
    brooke71 Guest
    Upland, CA
    I am very new at this and THINK this may be pretty easy but I need some help please creating 2 things. #1 is I would like to create a hyperlink from the text listed (www.idlife.com/healthyrn) as seen in the screenshot below.
    #2, I would like if someone clicks on this banner to go to a website as well (could be the same website or a different one if I wish like the screenshot shows).
    Site address is www.iuseidlife.com
    Thank you so much!
    P.S. I tried to look at some of the other support questions but I can't seem to see the images and screenshot attachments, any suggestions?
    Brooke Meyers
  2. brooke71
    brooke71 Guest
    Upland, CA
    I THINK I got the hyperlink ALMOST figured out. I have the text and link down however my next issue is when I click to hyperlink my text is wrong on the hyperlink. If you look at my screenshot when I hover it shows iuseidlife.com/www.idlife.com/healthyrn I need to find where I can take that off (the red text) and actually hyperlink to www.idlife.com/heathyrn As you can see from my Top Right Contact Details screenshot it appears to be correct. HELP!
    Many thanks in advance for the help!
  3. Nitesh
  4. brooke71
    brooke71 Guest
    Upland, CA
    Thank you Nitesh! Worked perfect! I am kicking myself because it was so easy. :)
    Brooke
