Help: Disable mobile site please...
Discussion in 'Dzonia WordPress Theme' started by mikelx37, Oct 10, 2013.
  1. mikelx37
    mikelx37 New Member
    Hello support team,
    Can you please assist me in disabling the mobile site? I am currently using dudamobile which I will disable soon, however I would like the site to look like it would on a PC instead of the responsive theme. Can this be done? Also, if I do disable the responsive mobile theme, would I have to start over in any way in designing the site?
    Thanks so much for your help!
  3. mikelx37
    mikelx37 New Member
    Can you tell if I use this "Static" theme whether I will have to start building the site from scratch all over again? I am not sure what I am supposed to do with this file and how to use it. Please advise and your help is greatly appreciated. Thanks!
  4. Piyush
    Your theme option content and css code in the Custom CSS section will remain intact while installing Static Theme, but if you have make changes in php files
    (like header.php, sidebar.php ,footer.php..etc.) of theme then you will loss your changes while Theme change.
  5. mikelx37
    mikelx37 New Member
    Thank you for your response. Can you advise if there will be an effect to the widgets as well? Also, if things don't work out with this Static theme, I should be able to switch back to my original "responsive" theme by an upload through the FTP platform correct?
  6. Piyush
    Your widget content will also remain intact while installing Static Theme, It is better to install it through your WordPress dashboard instead of through FTP.
    Yes, you can also switch back to your previous responsive theme.
