The website I am working on is crimefightinglawyer.com. I have several questions. (1) How do I get rid of the video on the main page? (2) I am having trouble with the footer. When I input the contact info into a html text widget I cannot space the information properly. When I click the automatically add paragraphs the information gets spaced properly but the font color changes and it becomes invisible... thoughts?
1.For your first issue We have checked your website and it shows that you have successfully removed the video. 2.For your second issue For spacing in a text use Code: and for changing the line use line break tag Code: <br>
Ok So i am having these issues too as i cannot see any text after i click the add paragraphs which i assume i have to do because all my text is a long ongoing story with no breaks. How can this be fixed with out using Code. which i have no idea how to add this even though you supply it Each every time some one asks how to do something. Come on guys i did not pay $100 to now have to learn code. And wouldn't it make sense to fix these issues so people don't have to bother you with the same support questions over and over. I guess i have to start my own thread for this very same issue... not very time efficient.
I have this same problem and none of the solutions in these threads work. I agree with Mike. A paragraph break should be a very basic function in these templates. Are there any new solutions for the paragraph problem? Also -- how can I get rid of the default grid in my html tables? Is there a simple solution? I found a workaround, but I'm not sure if this is effecting my functionality. AWPS
Hello, Please share the link of your website and also specify in which area you have getting this problem.
