Help!!! Issue with widgets when installing onto existing domain
Discussion in 'General InkThemes Discussion and Feedback' started by mlscott70, Nov 26, 2012.
  1. mlscott70
    mlscott70 New Member
    Hi there, whenever I install inkthemes at a location like http://maindomain.co.uk/Exampleclientsite/ I cannot access, move add or delete any widgets. Its like its locked.
    Please help as I need to get this site to the client!
    Matt
  2. Harmeet
    Harmeet Support Staff
    Which Theme are you using ?
    Can you please send me your Dashboard Login details, so that I can check your website. You can send the details at [email protected]
    Since, no one else reported the same issue, Can you please disable your Plugins and see whether the issue resolves for you. It might be possible that the widget section is locked due to some faulty plugin.
