Help me... Ink Appointment Pro Plugin and Book appoinment
Discussion in 'Appointway WordPress Theme' started by tinyvod, Mar 18, 2015.
  1. tinyvod
    tinyvod New Member
    I don't see Booked Appointments in Ink Appointment Pro Plugin,
    And I can't book in Book Appointment. ( Time is not Available )
  2. praveen
    praveen Support Staff
    Hello tinyvod!
    I think you have not configured "Booking appointment" settings properly.
    Please follow the video link given below. It will help you in configuring the appointment setting.
    http://screenpresso.com/=MHBpg
    Praveen
  3. jyschaefer
    jyschaefer New Member
    Not sure if you figured this out or not but I was getting the same thing. If I disable Ink Leads Capture Pro Plugin then Booked Appointments shows up.
  4. praveen
    Hello jyschaefer!
    There is no need to disable Ink Leads Capture Pro Plugin to show Booked Appointments.
    You can select your choice from your dashboard to show whatever you want.
    http://screenpresso.com/=JL0Ab
    Praveen
