HELP: problem with e-commerce plugin
Discussion in 'Figero WordPress Theme' started by hansvaessen, Dec 24, 2012.
  1. hansvaessen
    hansvaessen New Member
    Hi all,
    Hope someone can help me out:
    All of the sudden my e-commerce plugin doesn't work anymore:
    Check http:\\www.mrgps.nl\test
    You can place an order; pressing 'bestel' shows te shopping cart.
    BUT:
    As soon if I order i get a blanc page instead of the merchants-page.
    ALSO:
    as soon as I change te amount of products it will tell 'shopping-cart is empty'.
    Those two seem to be related.
    Anyone any suggestions how to solve this?? Would highly appreciate!
    Merry Christmas!
    hans vaessen
    It is plugin related issue, Therefore call plugin related support forum, They will give you exact solution for that issue.
