HELP: site hacked
Discussion in 'ColorWay WordPress Theme' started by almboyd, May 11, 2015.
  1. almboyd
    almboyd New Member
    My site has been hacked and an inappropriate line if text added below my logo, above the navigation. Please help me remove it. I cannot figure out where it's living.
    Sometimes it's not visible on desktop view but remains visible on mobile.
    http://lilygracecosmetics.com/
    Thank you!!
  2. sameerwalkar
    sameerwalkar Guest
    I visited your website.
    I am unable to locate the logo and the text, as it is not visible above the navigation.
    Also It seems that your page layout got distorted.
    So I will suggest you to kindly do a fresh install of your colorway theme it will solve your issue.
    Note: - Please create a backup of your website before upgrading the theme.
    Please follow the video link to delete theme from your dashboard :-
    http://screenpresso.com/=rcsig
    Now, download and install the latest version of the theme from members area.
    Or
    You can also try an easy way to install latest version of theme without creating any backup.
    Please follow the video link give below.
    http://screenpresso.com/=9Pv0f
    Hope it will solve your issue.
  3. almboyd
    almboyd New Member
    How do I prevent this from happening again? See screenshot attached. A href was added.
    I updated the theme which seems to have deleted it. Where would I go to delete it if it happens again?
  4. sameerwalkar
    sameerwalkar Guest
    In future if it happen then you can remove that specific anchor from header.php file of your theme folder.
    Hope it will solve your query.
