hi All, Hoping someone can help - Just put up a new website and the log in page looks really suspicious - this is the url for log in ... http://www.greyhoundracingtips.info...w.greyhoundracingtips.info/wp-admin/&reauth=1 instead of the normal www.greyhoundracingtips.info/wp-login Have I been hacked and what can I do?? Cheers guys any advice much appreciated
Hello, Just relax, Your site is fully safe. It is a custom login page of InkMember plugin. Your site is safe and you can login from there. Thanks & Regards Gourav Shrivastava
Hello, That is plugin login page. You can only login from there. The main reason behind it is registration form. Which is not available in WordPress default login page. So we have designed this login + registration page in the plugin. You can use it. It will work same as default wp login page. Thanks & Regards Nitesh Raghuwanshi
