Help with 2 things please?
Discussion in 'SaleJunction E-Commerce WordPress Theme' started by inspired, Jan 23, 2017.
  1. inspired
    inspired New Member
    1) When I create a new sub-page or move a main page as a sub-page it does not show as a drop down in the navigation menu at the top of the page how can I fix this? ( the sub-page just does not show up at all in the nav menu. )
    2) My products are displaying left one on top of the other instead of side by side. How can I fix this?
    Thank You
  2. Naveen
    Can you please share your site URL here?
    I need to check your site and will let you know the solution.
    Warm Regards!
    Naveen Kolhe
  3. inspired
    inspired New Member
    Hi Naveen,
    Sure it is websitelobby.com
    Thanks for the help!
    Is it possible the EDD plugin is just not working right with it?
    Elle
  4. Naveen
    I tried to check your site but, you have turned on the Maintenance mode so I couldn't.
    Regarding EDD, yes our theme is compatible with it, you can download the latest version of the theme from members area and use EDD with it.
    This may resolve your other issues.
    Naveen
