Help with a few tweaks...
Discussion in 'GeoCraft WordPress Theme' started by henrique25, Jun 15, 2014.
  1. henrique25
    henrique25 Member
    I'm preparing my Geocraft theme to start populating it.
    In the meantime, I need to make some changes... could you give me a hand, please?
    1) How can I had a Captcha (guess I wrote it right...) to the comments and reviews? And also, can I have comments and reviews done only by registered users?
    2) I would like to remove the "Add Listing" on the top right hand corner.
    Thank you in advance,
    Henrique
  2. henrique25
    henrique25 Member
    At this time, I would only need help with the removal of the "Add Listing".
    Thank you,
    Henrique
  3. Gourav
    Paste this code in Custom CSS
    Geocraft Settings > Theme Option > Styling Option > Custom CSS
     .header_wrapper .header .post_btn{
    display:none;
    Gourav Shrivastava
  4. henrique25
    henrique25 Member
    Hello, Gourav!
    Thank you for taking the time to reply to my post.
    Unfortunately, the code you have provided hasn't rendered any effect removing the "Add Listings" link.
    It could be because I have already entered the following code prior... (can't recall why I added it at this time, but it served its purpose some time ago when I began fiddling with the code :) ):
    .grid_10 {display: none;}
    Maybe it needs some code to separate both functions? (I'm not exactly a specialist editing code, so don't mind if this may seem a basic question :p )
    Thank you once again,
    Henrique (www.portuguese-market.com)
  5. henrique25
    henrique25 Member
    I am not an expert in coding as I said before, but it seems to me the provided removes all the header...
    Is that so?
    I would only like to remove the "Add listing" link...
  6. Nitesh
    To remove "Add Listing" link go to the
    geocrafttheme\library\controls\module_functions.php
    And remove code as shown in the image.
    Nitesh Raghuwanshi
  7. henrique25
    henrique25 Member
    Hello Nitesh,
    It worked :)
    Thank you!
