Help with Alt tags.
Discussion in 'Appointway WordPress Theme' started by pauljw, May 7, 2014.
  1. pauljw
    pauljw Member
    Hi, I am trying to optimise my web site using the guidelines given by Google. The web site is http://www.sheffieldcarpetcleaner.co.uk/
    I am using a Google tool.
    This tool tells me that my images have problems with Alt tags.
    My problem is that I know the images have Alt tags because I have put them there.
    It is telling me on one photo that it has one word as the alt tag and also that the word is
    second-feature-image.
    I need to make sure my pictures have the information in the Alt tags and not show
    'second-feature-image' as the word because this is effecting my seo efforts.
    Can you help me with this please.
    See screen shot.
    Paul.
    Go to front-page.php present in your theme directory and follow the instruction as shown in image given below
    Gourav Shrivastava
  3. pauljw
    pauljw Member
    Hi Gourav,
    Thanks for that.
    I have made a few sites for the surrounding towns for our carpet cleaning business.
    Should I assume that all the first page feature images will need changing.
    I am keen to get as much right on the Google side as possible.
    Paul.
  4. Gourav
    Yes, you can chage alt tag manually from front-page.php file.
    Or
    you can also use the "SEO Friendly Images" plugin, download it from WordPress.org and upload it.
    https://wordpress.org/plugins/seo-image/
    I hope it will fulfil your requirements.
    Gourav Shrivastava
