Help with Background
Discussion in 'Andrina WordPress Theme' started by taurea, Aug 18, 2015.
  1. taurea
    taurea New Member
    I set up my background on my 13 inch laptop and it looks perfect. However when I go to a larger display the background messes up. Is there a way to change the setting on my background so it stays the same?
    My website is www.TaureaAvant.com
    Thank you so much in advance!
  2. nitin
    nitin Guest
    body {
           background-size: cover !important;
    Nitin
