Help with Footer Copyright
Discussion in 'Covera WordPress Theme' started by sangermike, Jan 16, 2015.
  1. sangermike
    sangermike Member
    I insert an image in the footer copyright area but it's not sticking.
    It appears for a while but then disappears when I check again.
    Please help . Thanks
  2. Pramod
    Pramod Guest
    Hello !
    Please provide the URL of your website which will make us better understand.
    Pramod
    smith likes this.
  3. sangermike
    sangermike Member
  4. sangermike
    sangermike Member
    the small favicon to a link is not there anymore. it wont stick
  5. Pramod
    Pramod Guest
    Hello !
    Please also provide what code you are used on theme option for this.
    Pramod
  6. sangermike
    sangermike Member
    <a href="url to website" target="_blank"><img src="url for img"></img></a>
  7. sangermike
    sangermike Member
    it shows up before but the codes get erased so the img wont stick. I use the same code for my other sites and it works
  8. Pramod
    Pramod Guest
    Hello !
    Please check this code.
    HTML:
    <a href="http://roncoautorepair.com" target="_blank"><img src="http://roncoautorepair.com/wp-content/uploads/2015/01/ronco1.png" /></a>
    Pramod
  9. sangermike
    sangermike Member
    It messed up :( I went back to change url for image the codes were gone again and the big image is stuck
  10. sangermike
    sangermike Member
    I put in my old codes again so you may see the favicon but i dont know if it'll stick. then in my dashboard your codes left this sticky.jpg
  11. Pramod
    Pramod Guest
  12. sangermike
    sangermike Member
    The image is sticking for now. but there is that left over on the back office dash board
  13. sangermike
    sangermike Member
    Can you help me??? when i do the incognito browser. the image is gone again. I have that left over code in the WP dashboard which dont belong there so Im sure something messed up. And Even if logged out I cant switch back to maintenance mode (I went to url using incognito browser-cleared cache too)
  14. Pramod
    Pramod Guest
    Hello !
    Please check is there any plugin confliction ?
    This type of issue is not occurred in theme i have checked so many times.
    Pramod
    smith likes this.
  15. sangermike
    sangermike Member
    ok. it actually reverted to normal. just took a long while. i'll try your code again if the image will stick this time. Thanks
  16. sangermike
    sangermike Member
    ahhh it wont stick :( I'll just probably put it somewhere else but if you figure out why please let me know. Thanks
  17. Pramod
    Pramod Guest
    Hello !
    Generally we used text in footer area.
    You can add your image by custom coding in footer.php file.
    Pramod
  18. sangermike
    sangermike Member
