Help with footer widget area
Discussion in 'Smartbooking-Appointment Booking WordPress Theme.' started by sangermike, Sep 8, 2014.
  1. sangermike
    sangermike Member
    I tried playing with the footer widget area from the Appearance>Widgets tab and also from the Appearance>Customize tab but I can't see the changes on live site [www.pricechiropractic.org] Any ideas? Thanks.
  2. Yogesh
    Yogesh Guest
    Go to Appearance >> Widgets and set widgets in footer widgets area as shown below in screenshot.
    All widgets will display in footer section as shown below in screenshot.
    That will resolve your issue.
    Yogesh Bhade
  3. sangermike
    sangermike Member
    As mentioned. I did the above process but it didn't show on live site. I also tried on the Appearance> Customize>Widgets. It didn't work either. If I can't make it work, How can I just delete the background color intended for that block??
  4. Yogesh
    Yogesh Guest
    You can simply hide that area using following CSS in Custom CSS.
    .footer-sidebar {
    Or
    please send us your WordPress dashboard login details also the link of this thread at [email protected]. so that, we can have a look over the issue in details.
    Your website link:
    WordPress username:
    WordPress password:
    This thread link: http://www.inkthemes.com/community/threads/help-with-footer-widget-area.13770/#post-51219
    Note: When your issue get resolved, you can change your password.
    Yogesh Bhade
  5. sangermike
    sangermike Member
    I was able to add some widgets in the footer but had to log out then log in. refresh browser to see the changes. It's tedious but it's adding widgets. Good to know the codes if I just want to take out the footer widget altogether. Thanks.
  6. Yogesh
    Yogesh Guest
    Your Map issue on Contact Us page have been fixed.
    Yogesh Bhade
  7. sangermike
    sangermike Member
    Thanks! You guys are the best!
