Help with my footer widgets
Discussion in 'Andrina WordPress Theme' started by vickie, Oct 9, 2014.
  1. vickie
    vickie New Member
    Hello I have just upgraded the Andrina theme and would like some help with my footer widgets.
    1. I had three footer widgets then i did something experimenting and now have two but i am not sure how to get back the three that i really want.
    2.The bar that had the phone, hours and email address I would like to know how to get it back.
    3.How can I change the background color of the footer? It showed black when I had the three widgets now it shows a little of the black but I would like to change the color.
    4. Over my FB widget the color is red but I would like to change that.
    My website is www.acts1movingservices.com
    Thanks for any help you can give
    Vickie
  2. Yogesh
    Yogesh Guest
    .footer {
    background: black;
    .widget_inner.last h4 a {
    color: green;
    Write your color in above code.
    It will resolve your issue.
    Yogesh Bhade
  3. vickie
    vickie New Member
    Thank you Yogesh. I was able to get most of them resolved except No. 4.
    How do I get the information in the footer widgets centered?
    One other question...Is there a way I can get my social icons extending
    from the left side like how I was able to get the "Contact us" extending
    from the right side with FormGet? Thanks
  4. Yogesh
    Yogesh Guest
    color: green;
    Use social icon widget to add social icon.
    https://wordpress.org/plugins/easy-social-icons/
    Yogesh Bhade
