Help with page layout
Discussion in 'BlackBird WordPress Theme' started by faraway, Feb 28, 2014.
  1. faraway
    faraway Member
    Hi
    I'm wondering why I'm getting an extra line of blank space at the top of my pages. It doesn't appear on my posts. I've attached a couple of photos to give you an idea of what I mean. I would like the layout at the start of a page to look the same as the layout at the start of a post (i.e. no 'extra' blank space between the title and the social icons.) Is that possible?
  2. faraway
    faraway Member
    Hi
    I think I might have had a problem with a plugin so I've had to find a workaround and display my social icons slightly differently since I posted this thread originally. However, even with the workaround, there is still extra space before the social icons on a page that doesn't appear before the social icons on a post.
    I've attached a new screenshot of the post and the page. You'll see that the page still has extra unwanted space between the title and the social icons.
    Hope you can suggest a way to get rid of that extra unwanted space on the page setup.
  3. Nitesh
    Paste this code in Custom CSS
    .fullwidth {
    margin-top: 0px;
    Nitesh Raghuwanshi
  4. faraway
    faraway Member
    Hi Nitesh
    Thanks for the follow-up. Unfortunately, though, this doesn't seem to make any difference. I've added the text you provided to the styling option and I've cleared the cache, but I'm still getting the gap. Is there something else I need to do?
  5. Piyush
    .page-heading h1 {
    border-bottom: none;
    .page-content {
    margin-top: 5px;
    I hope this will solve your issue.
  6. faraway
    faraway Member
    Thanks so much, Piyush. That's worked. Can I just check: I've left in the text Nitesh suggested - is that OK or should I have removed it? Also, the page seems to 'flash' as it loads, with the space at the top of the page increasing significantly for a second or two before settling back to the correct layout. I'm not sure if I've explained that properly. You can try this link as an example: faraway quilts.com/quilts-for-sale
  7. Piyush
  8. faraway
    faraway Member
    Great. Thanks. Much appreciated. All the best,
    Piyush likes this.
