Hi we have installed pinterest pin it button plugin but it doesn't seem to show on the video posts, probably because it is a custom post type, we are wondering if you could help us so that the pin it button will show on the video posts the site is http://kinbakuvideos.com
Hello, Greetings from InkThemes, Could you please explain bit more where you want to add Pinterest, kindly provide some edited screenshots so that I can assist you accordingly. If you are unable to create screenshots then you can use www.screenpresso.com that will help you to create screenshots. Do let me know.
Hi, ok, so I have attached 2 screenshots (Regular Post.jpg and Video Post.jpg) as you can see on the regular post the Pin it button appears after the description while for the Video Post the Pin it button is not showing at all, Ultimately we want the Pin it button to show up before the title
