help with posts
Discussion in 'Guardian WordPress Theme' started by sangermike, Mar 12, 2015.
  1. sangermike
    sangermike Member
    I need help with the attached image. Thanks
  2. ankurjain
    ankurjain Support Staff
    Hello sangermike,
    You can delete high-lighted text by paste these code into :-
    Dashboard -> Appearance -> Theme options -> Styling options ->Custom CSS
    div#breadcrumb {
    .post-header {
    Thanks & Regards !
    Ankur Jain
  3. sangermike
    sangermike Member
    theme options.jpg I dont see theme options as in other regular themes
  4. sangermike
    sangermike Member
    ok i found it under the Guardian panel>General Options
  5. sangermike
    sangermike Member
    The theme is not cropped in smaller devices too and the video is not automatically playing on tablets and totally not showing up on mobile phones. Can you help?
  6. sameerwalkar
    sameerwalkar Guest
    We have forwarded your query to author you will get a response soon.
    Sameer
  7. dzung
    dzung New Member
    Can you please leave your url here? I'll dig more into this case, because the theme was tested to be support on multiple device.
  8. sangermike
    sangermike Member
  9. sangermike
    sangermike Member
    also from the same post article in 1st question above, the navigation item "contact" doesn't link to the contact form. and the logo doesn't link to home. Navigation "home" works.
  10. sangermike
    sangermike Member
    oh and footer copyright moved to align left unlike the homepage where its centered
