Help with sidebar and related posts error
Discussion in 'GeoCraft WordPress Theme' started by jrpubs, May 14, 2014.
  1. jrpubs
    jrpubs New Member
    We have long used the "Responsive Social Share Sidebar" plugin. With changing to Geocraft theme, Geocraft incorrectly places the plugin contents into all "related posts" info under a listing, page or posts. Geocraft also is trying to place the social share content into the sidebar on the recent listings widgets etc. It also causes the sidebar to render under the post instead of to the right and is adding the review stars back into the listing on widgets.( We have them custom.css coded off per your forum post).
    Pls seen here: http://reefcrawl.com/listing/lookout-lodge-resort/
    We do not use too many plugins, but this is one we need to keep. Can you tell us what to remove or code to add to custom.css to keep geocraft from placing this information in the posts and widgets? Or is there a similar plugin to use that you know works. We have tried several and they do not work well.
    Thank you.
    For this open
    geocrafttheme\library\controls\module_functions.php
    and remove code as shown in the image.
    Check image for reference.
    Nitesh Raghuwanshi
  3. jrpubs
    jrpubs New Member
    Thanks Nitesh,
    We did the edits you suggest and it helped somewhat. Still showing on widgets and related posts, though not as much content is showing now.
    Trying to see if the plugin author can cue us in to moving the social bar below the title line separator, to see if that will prevent Geocraft from picking it up and rendering it in the related post content and widgets. Bright side is the Publish dates are hidden now, thank you!
    JR
  4. Nitesh
