Hi: I'm encountering several issues with my site http://www.artdecodecor.com/ built using the Slice Theme Pro Version 1.2. Everything used to be working fine until a few days ago. 1. If you click on a product category you get an error in one of the template functions. The error message: Catchable fatal error: Object of class WP_Error could not be converted to string in /home/content/09/4547709/html/shop/wp-content/themes/slicetheme/functions/dynamic-image.php on line 269 2. The gallery page isn't showing any images even though the path to the images folder are correct. http://www.artdecodecor.com/gallery-2/ Please help me solve these problems. Thanks in advance! Regards, Henry
Hi: Sorry about that. I've deleted the Slice Theme V1.2 and replaced it with V2.0 but still have the same issues. Kindly look into the Products Category and Gallery page. Example error page is: http://www.artdecodecor.com/category/figurines/ The Gallery page isn't showing any images. Thank you! Regards, Henry
1.For your first issue We have visited your website the problem is occurring due to any one of the plugin you are using, Deactivate all plugins one by one and checkout which plugin creating this problem. 2.For your second issue Please check the address of your images that you are inserted in gallery, Upload correct address for images. This will solve your issue.
