Help with Update
Discussion in 'BlackWell-WordPress Business Theme.' started by vesity, Sep 19, 2014.
  1. vesity
    vesity Member
    Hi. I need to simulate an update of the theme. I'm sending an email with this link and specific question about my issue. Thank you!
  2. Pramod
    Pramod Guest
    Reply you soon related to your issue.
    Pramod
  3. vesity
    vesity Member
    Thank you. I've thought about it a lot, and realize I cannot take the risk that an update would mess up the testimonials section. I'd rather go back to the way it was before than take that risk. How would I restore it to how it was before it was customized? (testimonials increased to 6, and images removed)
  4. PankajK
    PankajK Support Staff
    Hi vasity
    You can backup your theme and then try updating the site.
    Please also make a back up your theme option data.
    Create a child theme now, this link may help you creating a child theme http://www.inkthemes.com/wordpress-child-theme/02/
    Place your old (customized theme) front-page.php in the child theme folder.
    In this way you can update your theme.
    However it more customization has been done to your theme you can add more files in your child theme.
    If your site is working fine, I would not recommend you to update your theme.
    PankajK
    Thank You
