Hi there team I put in a post below regarding changing the button text for my posts. However in the meantime I found this thread - https://www.inkthemes.com/community/threads/blog-post-button-text.18220/ and changed exactly as shown using wp-editor. When I updated my buttons were gone completely. I then changed it back to what it was with the same result. The site is about to go live so would really appreciate your help. Many thanks Maggie
Hello Maggie, You can share the changes that you wish to do there along with your site login details. We will do it for you. Warm Regards! Naveen Kolhe InkThemes.com
We have got your credentials and will check and revert you ASAP. Your patience would be appreciated, Warm Regards! Naveen Kolhe InkThemes.com
Naveen, thank you so much for all you and the team do to help and the support you provide. You are just the best!!! I appreciate the 'extra mile' you always go. I'm sure there are many others who feel the same. Cheers, Maggie
