Here is a Possible Solution for stretched images
Discussion in 'GeoCraft WordPress Theme' started by [email protected], Apr 10, 2013.
  1. elopezjr2005@yahoo.com
    [email protected] New Member
    I added this code to custom CSS for the image stretching problem. It corrected it. I did not have to resize any images. I added this to the Geo Craft theme. Here is the code:
    img { max-width:100% !important; height:auto !important;}
    I hope this helps and works for you.
    Ernesto Lopez
    San Juan, TX
  2. rogerb
    rogerb Active Member
    I'm trying it out Ernesto as I never seem to get things right- what does the !important wording do?
  3. TSMM
    TSMM Member
    Nope, didn't fix my issue. I am getting frustrated with a lot of problems with this theme. The images should look professional, not cut off or stretched.
  4. Nitesh
    Image will look professional if the inserted images are of correct dimensions. The exact dimension for the listing image is of width:448px and height:270px;. If the uploaded images are smaller or bigger than the specified dimension the image will be stretched, since the width is fixed in the theme to maintain the ideal listings page layout.
    If you want you can however make the height auto through the Custom CSS so the feature image automatically adjusts the height depending upon the width of the image, so that if the image is bigger than specified dimension it will still look professional.
    For that Paste the CSS code below in the themes options panel:
    .flexslider .slides img {
    max-width: 95%;
    display: block;
    width:448px;
    height:auto;
  5. azza
    azza Member
    Would it be sensible to use your code along side the smushit plugin to keep images sizes acceptably small
  6. molatin
    molatin Member
    Yep - great plug in
  7. nzcid
    nzcid Member
    Added to my site and it sure did reduce the size of some of the images..
    Many thanks.
